Norwegianmopar
1970 Plymouth Cuda AAR Restomod.
3 owner car. Bought new at Birmingham Chrysler Plymouth. 29,000 original miles on the body. Car has not been on the road since the early 70s. Original engine was gone early before 75'. Car was bought by second owner from a used car lot on Gratiot Maiden Acacia Avenue on the east side of Detroit.
This is a real Plum Crazy AAR 340 Six Pack automatic on the column. Rally Woodgrain dash with tach and full gauges. 3.91 with a sure grip rear end. Manual steering. Power disc brakes and AM radio. The car has the original qtrs. and trunk etc. Original floors and frame rails.
The car now has been lightly modified for better performance and braking. Brand new high quality paint in the original color. The interior is original and in great condition. It has a six way drivers seat. No console. Tinted windshield. Original bumpers that have been rechromed.
The motor is a Blueprint Engines 408 stroker small block Mopar making 500+ HP. . Transmission is a real AAR 4 speed. All new clutch and linkage. All new ceramic coated headers. All new exhaust. New Dynomax trans reverse flow mufflers like the originals. New Dales Cuda Shop repo AAR exhaust tips.
New aluminum radiator and shroud. New electric temp controlled cooling fan. MSD dist and ign. High performance mech. fuel pump. All new carbs and linkage. All steel stock T/A air cleaner. All new Moser Engineering Green axle bearings. All new Right Stuff 4 wheel disc brakes. All new gas tank and sending unit. All new brake and fuel lines. All new shocks.
17x9 rear Ventura wheel 5 spoke aluminum mags. 255/45/17 tires. Fronts are 17x8's with 235/45/17. This car has no miles and is fresh.
Can also be sold with 15" Rallys if desired.
$69,500. Might consider partial trades. Must be a nice turn-key musclecar only. Livonia, MI.
