FOR SALE 1970 Roadrunner 383 4 speed lemon twist
stephen_becker
New Member
5:32 AM
atlanta, georgia
This rare 1970 Plymouth Road Runner (chassis RM23N0A142952) is a worthy restoration candidate featuring its numbers matching 383 and 4-speed drivetrain. Though I make no claims of the car being complete, it appears that most everything is accounted for aside from the rear seat, air cleaner, etc..
A cool feature of the car is its Air Grabber hood (N96 option)
Although most everything inside is complete aside from carpet, the cabin is still quite a mess.
The fender tag is a bit crispy but it is still legible for the most part, though please note that the build sheet is not found in the car. Paint looks like it could be the original lemon twist finish, and according to coded info, the car was optioned with a stripe package. Here’s a handy VIN decoder along with a fender tag decoding tool and a color chart.
The car sat on the side of a house in a pole barn for almost 40 years in South Carolina. Usual rust around rear window and bottoms of both quarters but surprisingly everything else is pretty solid
The serial numbers are present on the block and 4-speed transmission, both of which appear to be original to the car.
Just did over $ 7,000.00 worth of service work to get the car running and driving again after almost 40 years of being off the road. It will run & drive around a parking lot and onto a trailer.
Work included:
FUEL PUMP
CARBURATOR
65 FLEET BATTERY
NEGATIVE BA lTE.RY CABLE
DRIVE BELT ?/N 7460
INTAKE MANIFOLD SET
THREADED ROD
INTAKE MANAFOLD
INTAkEVAllfYSET
FUEL FILLER NECK ANO<iASKET THROTTLE ADAPTER
8MXE HOLD OOWN HARDWARE fRONT 8RAKE HOU) OOWN HAROWAAE fl.EAR WHEEL CYLINOER REAR
WHEEL CYUN0£R FRONT
FRONT BRAKE HOS{S
BRAKESMOES
BRAKE SELF AOJOSU-R KITS
FROITT WHEEL BEARINGS
FRONT GREASE SEALS
MASTER CYLINDER
STtEL BRAKE LINE
REAR BRAKE HOSE
REAR BRAKE SMO£S
MlSC HARDWARE
CLEANER DEGIIEASER
ALltRNATOR
ENGINE OILflLTER
10W30 ENGINE OIL
LOG NUTS
FUEL FILTER
BRAKE FLUIO
HOSE CLAMPS
CARS.UT ATOR GASKET
llTV SEAlANT
COIL WIRE
WATER PUMP PULLY
AIR CLEANER ASSEMBY
FUU. HOSE 8-ULK
FUEl TANK
F\JEl TANK STRAPS
F\JEL SE.tmER UNIT
COMP1.ETE FUEL UNE
+ $ 2500.00 in labor
I am not on here very often so feel free to email me or call or text
Thank you
pixs
08FE846B-27D7-49FD-824E-86A2C2147B08.jpeg 84E0A26E-213F-4545-BA09-DCEDA090E50E.jpeg 4FBFEA0F-ABB3-4FF5-9C6D-B093E0A1B062.jpeg EED79A93-FF21-4277-A6B9-05CA63FF69D1.jpeg 1688805F-DD89-47B3-B7E4-F322347C67B6.jpeg 5D6B2511-70A7-41D0-8E35-1EE02B512000.jpeg E753238D-4B73-45E2-9474-861BB809984B.jpeg 1C3E0FF2-6E6E-4941-BC31-7CC2323D7347.jpeg DE6E7433-BFA7-4200-8D3C-5428D93A34F0.jpeg
$ 30,000.00 OBO - FOB Atlanta, Georgia
I have lots of pixs that I can text - Text me at Phone number removed by staff and I will text them back to you - Thank you
Contact the seller by personal message to exchange phone numbers.
NO COMMENTS FELLAS! IT"S IN THE RULES. JUST SCROLL ON BY INSTEAD OF COMMENTING!
