FOR SALE 1970 V code Super Bee
RubyredSavoy
12:12 AM
Putnam Valley, NY
Feedback: +6 / =0 / -0
For sale is my 1970 Super Bee. One of 599 440 six pack 4 speed hardtops made. It’s a pretty basic bare bones muscle Mopar, with manual steering and brakes. Just buckets, tic toc tach, AM radio and the hi impact FC7 Plum Crazy paint are the only options that the original owner ordered in late 1969 (He is still around too! As well as the second owner and I’ve spoken to both)
The numbers matching shortblock and trans were separated from the Bee in the mid 80’s. More than likely still in the Pacific NW area (sold new and spent until 2019 in Bellingham, WA).
It’s a very strong running car that drives nicely with just over 1,200 miles put on since completed in 2020.
The body and paint were professionally done by a Mopar shop on a rotisserie to a very solid shell. The Bee only needed minimal metal replacement. The center of the trunk floor, the rear window filler panel and a couple of small lower qtr panel patches, which were done using metal from a pair of NOS 1969 Coronet qtrs (were poorly removed from an old project and perfect for patch use). The fenders, doors hood and trunklid are perfectly rust free parts as well as the flawless original interior floorpans. Every part, nut and bolt has been restored. Painted using PPG Deltron FC7 with the correct white C stripe.
All new glass front, rear and side are new and dated coded with the Pentastars by ECS
Restored heater box with recored original heater core by Glen Ray
Restored four speed pedal assembly with all new bearings and bushings and the neutral safety switch as well.
Restored heater control panel by the late David Patik (owned PCG)
Restored gauge cluster with new silk screened gauges and rebuilt tic toc tach by Redline Gauge Works
Restored dash woodgrain by Instrument Specialties
AM radio rebuilt and the dash and optional rear speaker were reconed
All of the dash switches were restored by J&S Restorations
The original buckets and rear seats were completely restored correctly to OEM. New Legendary covers, foam and burlap. Done by one of the most talented Mopar seat guys around. He wove in new support wires through the burlap, like when new. The frames were blasted and powder coated black. The seat tracks were even completely disassembled, blasted, primed and painted. New headliner/insulation, package tray/insulation, ACC carpet, Legendary door panels with plastic vapor shields installed like OEM. New front window track guides and new rear track felts.
Topcat door glass whisker kit
Restored 3 speed wiper motor by Bruce Somers
Rechromed front and rear bumpers by Tri City Plating
Rechromed pistol grip assembly, inner/outer door handles, and vent window frames (not reproductions)
Every single wiring harness has been replaced with M&H Wiring.
The correct 4382-4375-4383 Holley six pack carburetors were rebuilt/restored by Scott Smith, along with the correct original air cleaner/Fram OEM filter.
The correct Prestolite dual point distributor was redone/recurved by Joe White
Original 2998956 26” radiator was recored/restored by Glen Ray Radiators
Original to the car Dana 60 3.54 with new bearings
Correct 1970 18 Spline transmission fully rebuilt with all new bearings, rollers, synchros, gaskets and seals. Nicely detailed and shifts very nicely, with new Ram XHD B&B 10.95” clutch, McLeod SFI flywheel and correct 513 bellhousing.
Correct original 1970 only reverse interlock linkage.
Correct F440HP block, now 505 cubic inch stroker, with a 440 Source 4.25” crank, H-beam rods and ARP rod bolts, Clevite 77 rod/main and cam bearings. Mellings HV oil pump, Dwayne Porter solid custom cam which was nitrided and EDM lifters. Crane ductile adjuster rocker arms. Rollmaster timing chain with Torrington bearing. Correct Hemi 7 quart oil pan. 440 Source aluminum heads with upgraded valve springs and Comp Cams 10* retainers/locks. Edelbrock aluminum intake and original 1970 valve covers and HP exhaust manifolds.
The original to the car driveshaft has new Spicer HD u joints.
All new Fine Lines brake, fuel and vapor return lines. New vapor separator and Carter fuel pump.
Added front disc brakes with 11.75” rotors (have the original 11x3” backing plates and spindles)
The original to car master cylinder was stainless steel sleeved and rebuilt by Brake and Equipment Warehouse.
ECS full exhaust with date coded mufflers and new chrome tips
Lots of NOS parts were used, most dash relays, horn switch, full lock set, ignition switch, key buzzer switch, etc…
Lots of money was spent on replating orignal nuts/bolts, brackets and door latches.
NOS rear taillight finish panel
PG Classics new taillight chrome bezels
New wheel opening moldings
Tony’s Parts 2944450 15x7 reproduction steel wheels (all 5)
F60-15 Polyglas GT front tires (and spare)
L60-15 Polyglas GT rear tires
Original to car restored bumper jack with the hard to find 104 hook.
This isn’t the typical “restored” Mopar, that’s just a shiny paint job with half assed work done to flip. Lots of time, money and effort were put into this one. Not perfect, but quite nice IMO.
$90k obro
