John Korn
New Member
I have completed a restoration on my 1971 Charger Super Bee. I replaced the brake system with new lines and components and am using DOT 5 now.
My metering valve is leaking from the bottom were the plunger rod sticks out. The fittings are all good, no leaking. I have tried a couple of different in-line tube metering blocks. I tried switching parts and different O rings etc. Nothing works. I feel that getting replacements from in-line tube is a waste of time and I think they are the only suppliers if you want a stock / looking replacement.
There was an article on how to fix this problem (either here or a different mopar site) with a .030 machining. I cannot find that article or reply now.
I also wanted to rebuild my old Kelsey Hayes one, but I cannot get one of the old brake lines out. I have tried everything on it.
If I could get an original one that could be rebuilt that may be the way to go.
Anyway, does anyone have a solution to fix this leaking metering valve?
