1971 dodge challenger 340
General Mopar Tech Discussions
  1. Alanj4
    Alanj4 New Member
    3
    0
    Apr 24, 2018
    NH
    Local Time:
    3:36 PM
    Hi All:
    I have a 71 challenger 340, trying to get it started. I have spark to the distributor but have no spark at the spark plugs.
    New Ballast resistor
    new coil
    new negative cable
    new voltage regulator
    Any ideas?
    Thanks a lot
    Al
  2. aeon280
    aeon280 Well-Known Member
    417
    320
    Dec 9, 2015
    Dfw
    Local Time:
    2:36 PM
    If you have spark going into the distro but not coming out check your distro cap and rotor for corrosion. Clean the contacts first and replace if corrosion is prevalent. You might also check resistance on the wires with an ohm meter. Here are some specs to start with. If the measurements fall outside this you may have bad wires prohibiting spark to the plug.
    0-15 in. (0-38cm): 3,000-10,000 ohms.
    15-25 in. (38-64cm): 4,000-15,000 ohms.
    25-35 in. (64-89cm): 6,000-20,000 ohms.
    Over 35 in. (89cm): 25,000 ohms.
  3. Don Frelier
    Don Frelier FBBO Gold Member FBBO Gold Member
    863
    866
    Oct 11, 2016
    Ionia, NY
    Local Time:
    3:36 PM
    Agree, one other thing would be to pull each wire from the cap and check for any corrosion or arcing build up there.
  4. rlem1977
    rlem1977 FBBO Gold Member FBBO Gold Member
    792
    788
    Feb 12, 2018
    Texas
    Local Time:
    2:36 PM
    I assume this is a breaker point / condenser ignition, not electronic. If so, are the points opening? Are they burned? As aeon280 and Don stated, check the rotor and the terminals inside the cap for corrosion.
  5. Alanj4
    Alanj4 New Member
    3
    0
    Apr 24, 2018
    NH
    Local Time:
    3:36 PM
    The rotor, dist cap and wires are all new.
  6. Alanj4
    Alanj4 New Member
    3
    0
    Apr 24, 2018
    NH
    Local Time:
    3:36 PM
    the wires, rotor and cap are all new
  7. Bb70charger500
    Bb70charger500 FBBO Gold Member FBBO Gold Member
    6,972
    5774
    May 2, 2014
    fl.
    Local Time:
    3:36 PM
    New doesn't mean it works by today's standards!
    Take a few pictures for us so we can see what ignition type you have if it's points if there not set right you won't get spark any further in the system!
  8. wyrmrider
    wyrmrider Well-Known Member
    1,461
    585
    Aug 26, 2014
    los angeles
    Local Time:
    12:36 PM
    did you have the dist out, wires all off?
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
