SOLD 1971 Plymouth Roadrunner true RM23 car
oilstrike
9:04 PM
Mount Sterling, KY
Feedback: +0 / =0 / -0
1971 Plymouth Road Runner factory bucket seat, console, big block (383), 4 speed for sale. Now Indy Cylinder Head 451 engine (563 HP, 650 lb ft of torque) oil pan to 780 cfm Demon carb. and a March pulley system. Passon Hemi 4 speed transmission I have the A833 transmission that came in the car. Upgraded to 4 wheel power disc brakes and power steering. Uninstalled; era correct mopar power window motors and switches, hydraulic power brake system, AlterKtion, tubular K-member with tubular upper and lower control arms fitted for torsion bars and power rack and pinion steering system. Price as is at $50,000 for everything that is NOT SOLD SEPARATELY. She is a thumper!
UNINSTALLED TO BE SOLD SEPARATELY; F.A.S.T. Six Barrel fuel injection system complete with computer, throttle bodies, and a custom fabricated intake for the Indy EZ1 heads, and a N.O.S. air grabber hood. Rear window louver kit and rear wing, made by Dayclona. No tire kickers please.
1971 PLYMOUTH ROADRUNNER Fender Tag Decoded.
Code Description E65 383-4 Barrel Roadrunner D21 Heavy Duty 4-Speed Manual Transmission RM23 R = Plymouth Road Runner M = Medium 23 = 2 Door Hardtop N1R N = 383 300HP 1-4BBL 8 CYL 1 = 1971 R = Windsor, ONT, CAN 251557 Sequence Number '251557' GK6 Paint Code: Dark Bronze Metallic M6T7 Trim Grade/Style/Color M = Medium 6 = Vinyl Bucket Seats T7 = Chestnut GT8 Upper Door Frame: Unknown At This Time 420 Date Built: 4 / 20 / 1971 005087 Order Number: 005087 V4X Roof Type OR Color: Black Canopy Vinyl Roof U Built to Specifications for USA Order 26 26 in. Radiator C16 Console w/ Buckets C55 Bucket Seats G33 Left Hand Outside Mirror - Manual / Chrome L31 Hood / Fender Mount Turn Signal M21 Roof Drip Rail Moldings R35 AM / FM Multiplex Sterio V21 Performance Hood Treatment END End of Codes
Options added; INDY CYLENDER HEAD 451 CID 563 HP, MSD Ignition system Race Demon 780 cfm 4 bbl Passon Hemi 4 speed, 10 ¾” clutch 700 lb pressure plate 4 wheel disc brake system with vacuum pump (zero manifold vacuum at the intake by INDY design) March pulley system and power steering pump Reinforced 8 ¾” axle housing w/Moser axles 15” American Racing S200’s One off aluminum hood hinges I have several systems not yet installed
Thank you for the offer, really nice cars. However I am losing the lease on our garage and need to sell both of my mopars outright.
What yellow was used to refinish the car ? What extent of body/metal resto ?
The previous owner repaired both lower rear quarters. It looks like he knew what he was doing. He painted the rr with some construction yellow. He welded the bumper bolts to the bumpers and ground them flush so he could paint them. In 2006 I had the unibody frame horns connected professionally. I'm pretty sure the bottom of one or both of the doors need rust repair. I bought this bird in 2005. All repairs to the body and paint was 20+ years ago. I also had the rallye instrument cluster rebuilt by red line, the amp gauge is now a voltage gauge. She sounds and works good.
Did this car come from NJ? Looks very familiar. Are there (or were there) Road Runner emblems on the strobe stripe where the bird is?
I'm not sure about NJ, but there was road runner name emblem on the strobe stripe.
Thanks for this info.
My friend owned and did the bodywork and paint on this car: was done in the very early 1990's. He is a good body and paint guy. The color is Chrome Yellow, a 1977 Corvette color (Code WA7074 or std #52).
He used it very little and then sold it to another friend who used it a bit and then sold it on around 2005-06. I have some pictures from 2004 to share if you want. Good luck with the sale.
Chrome Yellow, a 1977 Corvette color (Code WA7074 or std #52). Some quarter panel patches as I understand. Not sure what else. Paint and body are 30+ years old and still looks good it seems.
Thanks for the information. a guy at a KOI parts shop told me it was some construction yellow paint. I must have bought it from the second guy, I bought this car in 2006. I would like to see the pictures.
Cool, cool. Yes, you then bought this from my friend Timmy - a mutual friend of the person who did the car.
Will get those photos to you soon off my old laptop.
Did you rebuild the motor that was in the car when purchased, or build up a different one?
