WTB 1971 roadrunner hood latch
tyel
2:22 AM
Ohio
anyone know where I can buy a 1971 rr hood latch
I probably have one also if the member above can't help you. There are 2 different hood latches, which one do you need? One for external hood release and one for the inside hood release...
As you can see it is worn out
I only have an NOS latch and the used ones I have are complete with the center rad support and hood latch tray so I don't want to part them......
Just curious, are the external hood latch/release the same for 71/72 as 73/74? I have one from a '73. Be nice to know to label it correctly at the swap shows.
I think 72 started using a cable release instead of the pull rod. I have a 72 with the cable extra
