1972 Dodge Charger SE 440HP rear six pack carb fubared
Kobrak
9:53 AM
Alexandria, MN
Folks, I finally was able to fire up the Charger for the first time since ownership over two years ago. As some of you know, when I took possession of the car it had and still has a six pack setup on it. I have an issue with the rear carb where the float is along with the adjust screw, the threads are completely gone that the adjust nut/screw would turn into. So, I want to make sure I get the right one when trying to order just that section of the carb. This carb is stamped as a LIST- 4672, H14. See the enclosed pics. When looking for this bowl, do I search center float holley carb 1971?
Yes, the end bowls are available, center hinge float. The center carb bowl is the tough one to find.
There’s a place that can fix that but forgot the name and others might have carb shop names. Did my buddy’s squirter nozzle when his threads got stripped
Center carb available at Allstate. No outboards listed. Give 'em a call......
Looks like Chicago Carb has a "Get ya' by" outboard repop. Not an actual six pack.
I ran this dual feed bowl for quite a while on my front carb until I found a new replacement bowl. The site plug is on the driver side and at a slightly different level....
1. Chicago Carburetor has that bowl
2. You can use any Holley front “v-bowl” and block off the accelerator pump hole with JB Weld
