FOR SALE 1974 D100 Shortbed 440/727/8.75
Mopars For Sale
Thread Status:
  1. magvan
    magvan Well-Known Member
    175
    60
    Aug 3, 2012
    near disneyland
    Local Time:
    8:10 AM
    Contact Seller
    • Like Like x 2
    • magvan
      175
      60
      Aug 3, 2012
      near disneyland
      Local Time:
      8:10 AM
      00U0U_cdxwW8tTDBa_600x450.jpg 01717_2VafmF5Hhuw_600x450.jpg 00j0j_cAUJJGsZ5ud_600x450.jpg 00Z0Z_iMaOBLg9peY_600x450.jpg 00j0j_yDazvAzHky_600x450.jpg 00707_83tI8C1KRAc_600x450.jpg 00P0P_lh1Jg8SSeKz_600x450.jpg 00e0e_9RaGJSlXkKg_600x450.jpg
      • Like Like x 1
      • magvan
        175
        60
        Aug 3, 2012
        near disneyland
        Local Time:
        8:10 AM
        selling my 1974 D100 Adventurer short bed truck.
        this truck has a 440 engine, 727 auto trans,
        factory 8 3/4 rear end, disc brakes, power steering, trans cooler, sway bar & air conditioning, sport mirrors, sport rear bumper
        the engine is from a highway patrol car. has 63k miles on it, Edelbrock intake manifold, all new belts & hoses, mild cam, milled heads w/ hardened seats, 9:1 compression ratio. NOS mopar valve cover grommets, new fuel pump. 70lbs oil pressure on mechanical gauge. genuine mopar late model starter motor
        New big block radiator. 3 row high effieciency core, new hoses, new fan clutch, has fan shroud (often missing)
        HEI ignition module, hidden inside mopar chrome box, msd spark plug wires, msd coil
        new Hedman headers & dual 2 1/4" exhaust with 20" long Dynomax super turbo mufflers.(the long ones)
        transmission is a 727 with highway patrol torque converter, huge factory transmission cooler in front of radiator, driveshaft has new u joints, rear end has new pinion & axle seals.
        the front suspension has all new ball joints, tie rod ends, drag link, idler arm, control arm bushings, coil springs, etc it is all MOOG made in USA parts
        the rear suspension has new leaf springs, spring hangers, bushings, U bolts, hardware etc
        new brake system. rebuilt booster, new master cylinder, wheel cylinders, flex hoses, rotors, drums, pads, shoes, springs everything but the steel brake lines
        truck has factory cruise control. i removed it because i dont like cruise control but it is included and really easy to reinstall
        New custom upholstery done at an upholstery shop (no cheesy internet kit)
        New carpet kit (havent even installed it yet)
        New door seals
        new plastic clips on the door lock mechanisms & tailgate mechanism
        new bushings on the wiper linkage
        trailer hitch & wiring for lights
        NOS mopar heater core
        Factory dual gas tank truck. It has gas tank is under bed, it has NOS Mopar sending unit. new filler neck hoses, new vent hoses, NOS grommet on top of the tank for vent line, New vintage chrome locking gas cap. the in cab gas tank has been removed but i have it and it is included with the truck.
        truck has lots of power. you can stab the gas from a stop and it will lay 97 feet of rubber with both tires.
        the A/C system functions, but need charging. i havent charged it because i wanted to replace the 1 hose (45 years old original) before i had it done.
        all work done on this truck has been with Made in USA or NOS factory Mopar parts (except for very very few things that i couldnt find)
        no smog test required in the state of CA ever. 1974 is smog exempt
        never been wrecked
        tags are paid until 2020
        asking $9995 or make me an offer in person (i have spent more than that just in parts on this truck, not including buying the truck, or the hours and hours of labor)
        all work has been done within the last 7000 miles
        also comes with
        brand new carpet kit
        original dash panel with wood grain (but its cut kinda ugly around the radio hole)
        in cab gas tank
        original green hood (rust hole in bird bath like alot of them)
        the original cruise control from this truck
        714-642-4643
        • Like Like x 1
        • jprather
          jprather FBBO Gold Member FBBO Gold Member
          617
          375
          Dec 30, 2014
          florida
          Local Time:
          8:10 AM
          man I wish I had the $$$
        • pa moparman
          pa moparman Well-Known Member
          56
          8
          Mar 6, 2017
          Bruin pa 16022
          Local Time:
          8:10 AM
          I wish it was not so far from Pa I will have to see how much it would cost to ship.
        • pa moparman
          56
          8
          Mar 6, 2017
          Bruin pa 16022
          Local Time:
          8:10 AM
          Is this truck in Florida or Ca?
        • magvan
          175
          60
          Aug 3, 2012
          near disneyland
          Local Time:
          8:10 AM
          california
        Thread Status:
        1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
          By continuing to use this site, you are consenting to our use of cookies.
