icecat66
Need help with the 74 rally wire schematic.
when I bought the Bee thats 1 of the first things I did.Classic Industries sells the big color coded schematics for our cars.....best 18 bucks I have spent.....
nothing is damaged as of now just need it for installation.I REPEAT...IT DOESNT WORK FOR 72 and laters, meaning it doesn't match the actual wiring. Just partially
On this case is even worst, because that's standard cluster diagram and he would need Rallye cluster.
There is not a single wiring diagram on there from 72 and lates ( and not only Charger ) illustrating there the full wiring... i.e.: seatbelt safety warning system... amd several other stuff.
And on even more laters diagrams there are more mistakes.
If the harness was damaged and need to be fixed, a diagram could be needed, but if is just for assembly you won't need the diagram, really. You'll find the assembly pretty much straight up.
