BeepBeepRR
Well with regret I can't stay afloat much longer as things are right now. I am forced to part with my 440 that I built. My asking price is 4500 But thats negotiable.
1975 440 Block
Bored .30 over
Speed Pro Pistons with new speed pro rings
Year one repop HP manifolds new HP installation bolts and nuts
Balanced Cast crank and stock rods
New ARP rod bolts
all new bearings cam,rod and crank standard size.
Polished crank
Mopar M1 intake
Starter
new alternator brackets
new dipstick and tube
new motor mounts
New fuel pump
Edelbrock 1411 750 cfm I have a new blue accelerator pump to put in it as well as a rebuild kit and a rod spring and jet kit.
Moroso permalign valve cover gaskets
Set of oil pan gaskets and windage tray
New valley pan gasket
Summit cam SUM-K6401 new lifters for this cam
SFI Flywheel
Jegs 440 distributor
New oil pump and bushing
All new brass freeze plugs
Block was bored, honed,decked and cleaned
New AMD valve cover breather
New spark plugs and new wires
Rebuilt 452 heads with larger springs for the cam. I do not remember the spring information
Basically all the engine needs is to be put into a car and break in the cam. It already has Lucas break in oil in it. I will include a 727 with the engine. If you are a transmission guy I would suggest checking it out. The guy it came from said it was rebuilt. But check it out for your peace of mind.
1975 440 Block
Bored .30 over
New ARP rod bolts
Polished crank
Mopar M1 intake
Starter
new motor mounts
New fuel pump
SFI Flywheel
