Does anyone have part numbers for these shackles? Seems to be no info around. Listing show part numbers for 1979 Chrysler Cordoba but no Dodge Magnum. Are the shackles different? Thanks for any help.
UPDATE: Received new shackles for Cordoba, but they are not the same as Magnum. The new shackles are about 3/4 inch shorter in length then the Magnum. Should work, just a little lower, I had the springs redone so ride height should be fairly close. Thanks Again
Cordoba and Magnum shackles are the same as mentioned. The fact that the new part is different is not due to the difference of the marque of the cars. Rather, I suspect it is that the replacements are incorrect in their dimensions. Happens a lot in the aftermarket. Glad you could make them work regardless.
