Thirty6fordguy
Which rear end would you guys prefer in a Super Bee that sees quite a bit of Hiway driving? Tires are 27 tall, mild cam , 383. 727 TF transmission.
A 3.55 will cause you engine to rev higher at a given highway speed than a 3.23. On the other hand, a 3.55 will allow you to accelerate faster. So you need to pick your preference...Why would you choose the 3:55? Is it higher?
my 72 Demon with a mild 340 has same rear tire size, 4spd and I am running 355'sI recently changed from a 3.91 to 3.55 to help drop the revs for freeway driving. The difference in off the line acceleration was immediately noticeable...would not want to go any lower the 3.55.
At 75 MPH with a 1:1 drive ratio and 28" tire (275/60-15):
3.23 = 2900 RPM
3.55 = 3200 RPM
3.91 = 3500 RPM
You need to look and measure it. Is the car is totally original? The 3rd members in these cars usually were swapped out at some point in time in the last 48 years or so. Also, the factory didn't always follow it's own 'rules' for what parts should go into the car. If there was a hiccup on the assembly line, it wasn't all that unusual to plug in whatever that was available to keep the line going.Good explanation. Also would my Super bee have the large yoke or small yoke? And will they interchange?
