3/8 to 5/16 fuel line
dart6
5:01 PM
Auckland
I have to do a long trip with my warm 440, Holley 850 do. I want to take the carter J7 4426S carb off my 383 RR.
The charger has 3/8 line and the RR 5/16 so I’m thinking of a 3/8 to 5/16 step down fitting. Mechanical fuel pump. Does anyone think I might have fuel pressure problems?
What pressure do the Carter carbs like to see
Cheers
Factory 3/8 fuel line equipped Mopars had 5/16 from the pump to the carb... 3/8 was only used from the tank to the pump.. So no, reducing the line from the pump to the carb doesn't cause any issues.. Carter carbs like 5-6 PSI
Cheers
If the car is automatic transmission, and you're not thrashing the car ....should be fine. Most auto 440 cars were equipped with a 5/16" line from the tank. My '70 Road Runner had a 750 Holley vac-sec and headers with only a 5/16" fuel line and I never starved of fuel....even at 150 mph. Four-speed car also.
Yup, 5/16 for 383... Also 5/16 with 440 HP through 68... And the 69 440-6bbl cars...
Cheers guys i'll go ahead with it then
Is 630cfm for the carter correct?
What years got the "Factory 3/8 fuel line equipped Mopars had 5/16 from the pump to the carb" ?
Starting in 69 on 440 HP applications.. Prior to that only the 426 Hemi..... LP 440 & all smaller engines only got 5/16... So if you are looking at a dilapidated old junker & see a 3/8" fuel line pay attention, it might be something interesting...
Thank you. Interesting. I thought 67s, such as 67 GTX's, had 3/8 from tank, and then 5/16 from pump to carb.
