Old Frat
Well guys I'M back again:
As I stated my last post The engine is running, But I have an oil leak at the Filter.
I checked to make sure it had the proper filter installed, I tightened it jut a tad more by hand, still leaking.If I recall these engines had originally had a canister type filter at one time, I checked the threaded tube that the spin-on screws on to and found the seal (think at one time it was an "O"ring, which was in very bad shape, but I'M thinking there the plate the filter seats against has a gasket under it which seems to be where the leak is. I don't know if the guy that rebuilt the engine or the guy that installed it had that plate out or not. From what I have seen he didn't have a clue as to what he was doing. I attempted to remove the plate to see if the gasket had been replaced or the Idiot just used silicone. My problem is the plate as I recall should just pop out with a little coaxing, this thing will not move. Any suggestions? or Am I wrong about the plate coming out?
