YY1
So... my 318 2 barrel has been running just fine since I got it.
I have it idling at 650 in drive, and it's pretty smooth- can balance a lighter on the air cleaner lid.
last weekend I changed the plugs. They (Autolite P66 @ 30) looked fine- light brown, dry, etc.
I put in Autolite 66 gapped at 35. Ran just like before.
Tuesday I siliconed the hell out of my a/c box gasket and surprise, suceeded in fixing the condensate leak.
Today, I'm driving around, enjoying the a/c, stopping at pawn shops to look for another high CFM compressor.
Kind of stop/start city driving, but hey, that's the way it goes sometimes.
On the return leg, it diesels really bad a couple of times- never done it before.
A couple times I shut it off in gear, so as not be embarrass myself.
It also seems to be pinging under moderate load sometimes.
I get back, almost home, and it stalls making the last turn, and won't restart.
I coast in, pop the hood, and gas is seeping out- between the carb and intake.
20 minutes later, I go out and after a little goosing, it fires right up, and runs fine for 10 miles, no pinging.
WTH??
I put a timing light on it (vac advance still hooked up) and it was at 10* breifly, then off the scale...in "P" at 1000 RPM.
In "D" it was dead on 0*.
Motor's says 0* with vac unhooked and plugged, and idle should be 750 in "N".
I don't think it would stay running in "D" if it idled at 750 out of gear, especially with the a/c on.
Any ideas? (besides setting the idle and timig to spec, which I'm trying right now)
Why would it just start acting like that and then clear up?
WTH??
