ord27
I installed the newly rebuild Ac/heater box (thanks Steve).
The previous owner had bypassed everything and ran the hoses in a loop. If I put the hoses back on the "ports" that they fit, I have: the lower hose from the valve, connected to the inner fitting on the heater core....
........the outer heater core fitting going to the thermostat housing
........and the lower (larger) port of the water valve going to the water pump
the "book" seems to show just the opposite
question: how does water flow?
does it exit the thermostat, flow through the heater core, and return to the water pump? or just the opposite?
