1. moparnorth
    moparnorth Well-Known Member
    176
    19
    Apr 9, 2019
    toronto, canada
    Local Time:
    9:01 AM
    which is the better gear ratio for city and highway driving 323 or 355?
  2. Don Frelier
    Don Frelier FBBO Gold Member FBBO Gold Member
    3,731
    4180
    Oct 11, 2016
    Ionia, NY
    Local Time:
    9:01 AM
    City 3:55
    Highway 3:23
    But your not talking a big difference.
    If you have a lot of torque, then 3:23
    • Agree Agree x 3
    • dryheat
      dryheat FBBO Gold Member FBBO Gold Member
      841
      529
      Feb 4, 2011
      Glendale, AZ 85308
      Local Time:
      7:01 AM
      What RPM do you want to be turning at 70 MPH?
      • Like Like x 1
      • Agree Agree x 1
      • #41
        #41 Well-Known Member
        372
        633
        Oct 18, 2012
        Lewis County, WA
        Local Time:
        6:01 AM
        ...and how tall are your rear tires? .... and what is the typical highway speed limit in your neck of the woods? .... and how far/how often do want to comfortably drive at highway speeds? These factors make a big difference in choosing.
        • Agree Agree x 2
        • hunt2elk
          hunt2elk FBBO Gold Member FBBO Gold Member
          7,017
          5906
          Jul 15, 2009
          WI
          Local Time:
          8:01 AM
          Depends on your rear tire size also.
        • moparnorth
          176
          19
          Apr 9, 2019
          toronto, canada
          Local Time:
          9:01 AM
          rear tires 275-70-15 also highway drive 25% of the time
        • moparnorth
          176
          19
          Apr 9, 2019
          toronto, canada
          Local Time:
          9:01 AM
        • 70chall440
          70chall440 FBBO Gold Member FBBO Gold Member
          2,542
          3621
          Feb 11, 2018
          Yelm, Washington
          Local Time:
          6:01 AM
          What motor/trans? I just picked up a 70 Satellite with a 440 and Richmond 5 speed, it has 3.55's in it and runs 2100 rpm at 50 mph. It feels like it needs another gear, so in this car I would run 3.23 as the 440 has plenty of torque to be fun in 1st and 2nd around town. I have 3.23 behind my 408 stroker (making around 500hp) and A833, it seems pretty good but I confess I have not had it past around 60 yet.
        • moparnorth
          176
          19
          Apr 9, 2019
          toronto, canada
          Local Time:
          9:01 AM
          also with over drive as a 4 speed with 383
        • Curiousyellow71
          Curiousyellow71 Well-Known Member
          668
          477
          Jun 18, 2019
          Nebraska
          Local Time:
          8:01 AM
          Always loved 3.55s better from a standing start. If you plan to cruise mostly and long trips then 3.23. If you want to have the best of both get a good tight convertor that flashes high and run the 3.23.
          If 4 speed then 3.55 is probably better then 3.23 overall depends a lot on the 1st gear ratio.
        • hunt2elk
          7,017
          5906
          Jul 15, 2009
          WI
          Local Time:
          8:01 AM
          Those are 30 inch tall tires. Between your 2 choices given, you will want 3.55's imo.
          • Agree Agree x 3
          • 747mopar
            747mopar FBBO Gold Member FBBO Gold Member
            12,558
            15762
            Oct 30, 2012
            ohio
            Local Time:
            8:01 AM
            Before I installed the 6 speed I was running around 3,500 rpm on the freeway with 3:55's, not a relaxing drive at all. 3:55's are awesome for 55-60 mph and under. Pretty sure my tires were closer to 27" though.
            • Like Like x 2
            • moparnorth
              176
              19
              Apr 9, 2019
              toronto, canada
              Local Time:
              9:01 AM
              what is a proper first gear ratio
            • Curiousyellow71
              668
              477
              Jun 18, 2019
              Nebraska
              Local Time:
              8:01 AM
              For a 4 speed the close ratio 1st gear is really tall to get the car going out of the hole. The wider ratio transmission with the lower granny is easier to get the car moving especially w highway gears.
              Most 833s have a 2.44 or 2.47 first and some have a 2.67ish first gear, I think a few had a 3.09..
              2.44 with 3.23 it's pretty high geared coming out of the hole because there is no convertor to assist w the launch, the clutch needs to be pretty good to handle any traction.
              727s are 2.45 but the convertor really helps w the launch . Modern converters like a dynamic or ptc you can cruise like a stock convertor but get a race car launch...that's why it's the best of both.
            • BSB67
              BSB67 FBBO Gold Member FBBO Gold Member
              1,493
              1200
              Jan 18, 2018
              PA
              Local Time:
              9:01 AM
              I'm not exactly sure what you are saying here. Is it an overdrive 4 speed manual transmission? If so, should be 3.09 first, and 0.73 OD. I would go 3.55. That would be like a 4.10 behind the more typical 2.66 first gear 4 spds. But your tire is really tall.
              • Agree Agree x 1
              • VANDAN
                VANDAN FBBO Gold Member FBBO Gold Member
                1,706
                2924
                May 27, 2011
                Western NY
                Local Time:
                9:01 AM
                I would use the 3:55 all day long, if you like to have fun with the car...
              • Longknife
                Longknife Well-Known Member
                155
                152
                Jul 12, 2017
                Illinois
                Local Time:
                8:01 AM
              • vintage chromoly
                vintage chromoly Well-Known Member
                1,980
                3554
                Nov 13, 2010
                ohio
                Local Time:
                8:01 AM
                3.73’s!
                :popcorn:
                • Like Like x 1
                • Curiousyellow71
                  668
                  477
                  Jun 18, 2019
                  Nebraska
                  Local Time:
                  8:01 AM
                  I missed the 4 speed overdrive post. They have a huge jump between the gears.l basically a 3 speed w od added.The 3.09 first isn't going to care much whether it has 3.23 or 3.55s. IMO the od 4th is going to work better w 3.55s. To cruise around and start in first the 3.09 is really, really low and slow w either gear.
                • moparnorth
                  176
                  19
                  Apr 9, 2019
                  toronto, canada
                  Local Time:
                  9:01 AM
                  sorry the tires are 275-60-15 not 275-70-15 and O/D with 4 speed
                1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                  By continuing to use this site, you are consenting to our use of cookies.
