383/440 proclaimed horsepower ?
pearljam724
6:34 AM
U.S.
What was the approximate/proclaimed horsepower of a factory built 383 and 440 big block ?
Never mind. I found a large article on it
There were a few different specs for each engine. There was a 383 2bbl, 383 4bbl and a 383 HP and likewise for the 440. Each version had a different HP rating.
325 for the HP 4 bbl 383
390 for the 440 HP 6 pak.
Corrected now remove my red X lol
I thought the 440 bbl topped out at 375hp and only the 6 pack 440 was rated at 390?
440 HP x 4bbl = 375HP/480ft lbs torque
440 6bbl = 390HP/490ft lbs torque
383 HP 325HP as stated, w/440HP Heads and Cam
What was the torque output of a 383HP?
:popcorn2:
:popcorn2:
1966
265
Horsepower…….. V8-361 2 Barrel 4.125 x 3.375 361 9 265 @ 4400 380 @ 2400 45-65
270
Horsepower…….. V8-383 2 Barrel 4.25 x 3.375 383 9.2 270 @ 4400 390 @ 2800 45-65
325
Horsepower…….. V8-383 4 Barrel 4.25 x 3.375 383 10 325 @ 4800 425 @ 2800 45-65
350
Horsepower…….. V8-440 4 Barrel 4.32 x 3.75 440 10.1 350 @ 4400 480 @ 2800 45-65
1967
325
350
375
1968
290
Horsepower……… V8-383 2 Barrel 4.25 x 3.375 383 9.2 290 @ 4400 390 @ 2800 45-65
300
Horsepower……… V8-383 4 Barrel 4.25 x 3.375 383 10 300 @ 4400 400 @ 2400 45-65
330
Horsepower…….. V8-383 4 Barrel 4.25 x 3.375 383 10 330 @ 5000 425 @ 3200 45-65
350 Horsepower.
. . .. V8-440 4 Barrel 4.32 x 3.75 440 10.1 350 @ 4400 480 @ 2800 45-65
375 Horsepower.
. . .. V8-440 4 Barrel 4.32 x 3.75 440 10.1 375 @ 4600 480 @ 3200 45-65
1969
290 Horsepower.
. . .. V8-383 2 Barrel 4.25 x 3.38 383 9.2 290 @ 4400 390 @ 2800 45-65
330 Horsepower.
. . .. V8-383 4 Barrel 4.25 x 3.38 383 10 330 @ 5000 425 @ 3200 45-65
335 Horsepower.
. . .. V8-383 4 Barrel 4.25 x 3.38 383 10 335 @ 5000 425 @ 3400 45-65
350 Horsepower.
375
Horsepower….. V8-440 4 Barrel 4.32 x 3.75 440 10.1 375 @ 4600 480 @ 3200 45-65
390
Horsepower…..
1970
290 Horsepower.
. . . V8-383 2 Barrel 4.25 x 3.38 383 8.7 290 @ 4400 390 @ 2800 45-65
330 Horsepower.
. . .. V8-383 4 Barrel 4.25 x 3.38 383 9.5 330 @ 5000 425 @ 3200 45-65
335 Horsepower.
. . .. V8-383 4 Barrel 4.25 x 3.38 383 9.5 335 @ 5200 425 @ 3400 45-65
425 Horsepower.
. . .. V8-426 Two 4 Bar. 4.25 x 3.75 426 10.2 425 @ 5000 490 @ 4000 45-65
350 Horsepower.
. . .. V8-440 4 Barrel 4.32 x 3.75 440 9.7 350 @ 4400 480 @ 2800 45-65
375 Horsepower.
. . .. V8-440 4 Barrel 4.32 x 3.75 440 9.7 375 @ 4600 480 @ 3200 45-65
390 Horsepower.
1971 The beginning of the end Here comes the smog era...
275 Horsepower.
. . .. . V8-383 2 Barrel 4.25 x 3.38 383 8.5 275 @ 4400 375 @ 2800 45-65
300 Horsepower.
. .. .. V8-383 4 Barrel 4.25 x 3.38 383 8.5 300 @ 4800 410 @ 3400 45-65
335 Horsepower.
. .. .. V8-440 4 Barrel 4.32 x 3.75 440 9 335 @ 4400 460 @ 3200 45-65
370 Horsepower.
. .. .. V8-440 4 Barrel 4.32 x 3.75 440 9.7 370 @ 4600 280 @ 3200 45-65
385 Horsepower.
. .. .. V8-440 Three 2 Bar. 4.32 x 3.75 440 10.5 385 @ 4700 490 @ 3200 45-65
lol for some reason I just overlooked the 6 pak. But posted its HP rating. go figure.
My best friend had a 70 4 speed, N96 Roadrunner back in 79-82. I hooked him up with the owner who sold him the car.
My bud put a hydraulic cam (284°/.488)??
Intake, headers, gear.
It was a contender on a lot of "chance encounter" street races. Low 13 second car. A blast to ride in.
My 70 V-code Roadrunner with cam, headers, 6bbl, 71 steel crank 440, manual transmission runs so strong it's almost like a different engine than the 71 440 4bbl in my 71 R/T Charger. It's the car, gear, rear end, all lighter, leaner, better, more tactile than the Charger was.
383 and 440, both great engines.
I'd like to see a 383 equipped in a similar manner as a 375HP/396 and see what kind of output the 383 would make.
IIRC the 375/396 had a solid cam and the big square port heads. Rated at 375 in a Chevelle and 425 in the Vette. We are building a 68 Chevelle 396 Hedders all the usual HP goodies, will see how it stacks up against my 68 440 R/R.
Should rev a little easier and raise the rpm curve at a given horsepower, and not crank out quite so much torque. Still a blast i'm sure. I think we often forget what a popular engine it was.
wonder how B1 heads compare to those chevy "big port" heads?
One of my best buds had a ‘68 Satellite and he couldn’t stay with my Bee. He was rated 330hp, mine 335. Different drivers(?)
That was a very good read.
I miss him on FABO, he also did threads he called "match race" where he paired 2 musclecars from back in the day in a play by play style race. They were great. Paul was a racer from back in the day, and he made learning about that era so much fun.
