msharri11
New Member
At long last, I'm finishing up a project on a stroked / bored 383 six pack in a 1968 Charger R/T (449 cu. in.).
(It's an automatic and I've properly solved the kickdown linkage issues already.)
Someone, somewhere must have built a low block (B engine) with a six pack (six barrel).
My issue is the throttle cable. The 440 six pack throttle cable I bought from Mancini Racing quite a few years ago it is really too long.
While I've been able to make it fit, it's bent too sharply in a couple of places and I've had to add a smaller diameter throttle return spring
inside the normal six pack spring to the carb to get the throttle to close to idle. It works but it's not ideal.
Anyone have a REASONABLE suggestion for a somewhat shorter throttle cable that still allows the center carb to open fully?
Thanks.
Thanks.
