PLMHEMI
- 11:47 AM
- Oct 31, 2019
- Ray Twp, Michigan
You dont need this bracket if you are going to "manual brakes"What makes this a hemi booster bracket?
Im getting ready to convert from power to manual brakes before l install the hemi.
Will this allow me to remove the valve cover and which booster do l need?
Can l use this and keep the PB?You dont need this bracket if you are going to "manual brakes"
Yes, this is the bracket to raise the Original style Bendix Booster.Can l use this and keep the PB?
Which booster do l use?
How much for bracket and booster?Bendix boosterView attachment 870492
I believe it is 8" Diameter, maybe some other members here can chime in on this and help..?What diameter is the hemi booster?
Spark socket, 3"+ 1" extensions ratchet to loosen plug remove extensions hook socket if plug falls a hose on to plug.I can replace #7 plug with my booster on,oem style booster none disc car.
Takes some tools,& patience but can be done
Without removing anything else.
Uh OhWe are sure messing up PLMHEMI's ad, dam.
how far off does it offset?426 HEMI POWER BRAKE BOOSTER BRACKET, THIS IS A REPRODUCTION UNIT THAT I'VE HAD FOR MANY YEARS AND NEVER USED. I BELIEVE I BOUGHT IT FROM PHIL NEWCOMB BACK IN THE DAY. $400.00 OPEN TO OFFERS...
View attachment 870438 View attachment 870439 View attachment 870440 View attachment 870441
