Oh ok 383 rods won't work it's a rb engine like a 440 instead of b engine like a 383?It would use the same length rods as a 440
Thanks the info I'll get some 440 rods.It would use the same length rods as a 440
Piston pin and deck height. If you could find steel 383 pistons maybe a blower engine otherwise compression would be way down.Hmm, with a longer rod you could probably use a 383 piston.
It was for sale on here at one point the 426 was. the seller couldnt sell it and basically gave it to me.he wasnt goin to use it at all.l need 440 rods 383 won't work since its a rb 426 is.l have a 440 and 383 this 426 wedge will be spare engine.if something happens to the one of the others.Check with summit. Got my 383 crank rods out of Texas. They where limited on how many they had in stock. May run into the same problem with the 426. Think I would go with a 440 over the 426. But it is up to each one what they want. Steel piston's with floating rod's. Could not find any press pin piston's.
If you are looking to restore this, I have a factory intake for a 426 wedge. According to the casting #s.I got a real 426 wedge block today with crank only.l was wondering if 383 standard ly rods would work? places to get pistons for it?
I seen custom pistons aren't cheap.if anyone has any good used ones for sale id be interested.i need 030 over ones.I think I have a set of early Stage rods that would go very nice for a Clone Maxie build too..... putting together a real 426 wedge is only a challenge because of the pistons (cost for custom), and the maxie heads, but it would be very cool to build something vintage and not compromise by butchering it into a 440 or some such. (just my 2 cents). Crossrams are out there, heck i even have a vintage NASCAR max port single carb manifold....
Where you get pistons for it at?I’m building a 426 Street Wedge for my car. It will be 30 over with a 4.25 crank with Chevy big block rods. It will end up being 489 cu in.
