I was wondering if some of you engine guys could give some input for a decent motor build. This will be going in my 69 Charger 4-speed Dana 3.54 and will probably be running 275/60/15 rear tires @ 28" unless I find some wider ones that are about the same heighth. I want a dependable, streetable car that runs well on 91 octane max. It will never be run on the strip, but I want it to have some get up and go. I like a lumpy cam sound, but have a vac. brake booster and headlight doors that will need to operate. What I have is a 69 HP block that I have had cleaned and magnufluxed that will easily clean up with a .030 bore. 906 heads, factory intake, and factory exhaust manifolds. The block and stock HP exhaust manifold are the only 2 things I am set on using for sure. I am open to anything else. What would be the best bang for the buck?
Forgot to add that I have the stock forged crank, rods, and pistons.
