nigel
So im building up my 440 and I have a few questions regarding piston orientation. I'm using sealed power l2266f30. What I noticed is the wrist pin is offset in the piston so that would indicate that the drivers side bank arrow would face forward while the passengers side would face rear to keep them the same. I believe I am correct but if not feel free to give some advice.
Also I had the machine shop install the pistons onto the rods and what I noticed today while installing new rod bearings if I run the pistons as stated above the rod chamfer won't be on the Web side of the crank and the squirt hole (which is useless seeing as modern bearings don't have a notch) will be facing the block wall instead of the cam. Is this a major issue where I will have to have the machine shop rotate the pistons 180 degrees on the rods?
