440 cam
moparwmac
7:07 AM
Kansas City, MO
Has anyone had any previous or current experience with comp cams magnum 305h, 525 lift and 243 duration at .050 in a 440 with headers, single plane
intake, 850 carb, alum heads, 3000 stall and 3.91 gears?
If so how did the setup work for serious street occasional strip.
Thanks for any help:santa:
Used a similar cam by a different manufacture with 240Duration@ .050 in a 440+.030, 906s,TM6, 850 & 3.91s. Worked great but my converter was a 3800 stall used with a 28.5" tall tire. That is about as big of a hydralic cam I ever tried. Sold the car to a bud and hes still driving the same combo after 5 years, no problems.
Make sure you go to an adjustable rocker you will need to set the lifer preload. Get your rocker setup before you measure for pushrods. We like the comp cams stuff and have not had any problems. They also sell a Pushrod lenght checker tool if you dont have one. Good Luck.
