Looking at a 440 later today that's roughly an unassembled short block. Seller says the rotating assembly has been balanced for a neutral torque converter. LY rods and aftermarket pistons. Rods have been resized with new bolts. Photos show some material added to at least one counterweight. I've not seen the balancer nor have I heard of this before. Can a cast crank assembly be redone to allow use of a 'normal' converter?
In response….
“ can a cast crank assembly be redone to allow use of a normal converter?”…..
Kudos 2 U For your analysis & critical
Thinking skills …… it’s a vital component of
Hot Rodding….. like putting a gen3 Hemi
Hellcat drivetrain in a Prius !! That’s Great !
Then Race It On Woodward … Roadkill Style !
MUCHO & GUSTO
YES you should internally balance any engine
IMO , it will run better , last longer & be more fuel efficient! WHY ??…. Because its
In balanced form is the metallic version of
The 5th Symphony! Precise , planned &
Harmonious …..
Mass Production Equates to Numbers & not necessarily finely tuned harmonics & performance. Wouldn’t you agree ?
So if you’re engine is neutral balanced internally you wouldn’t need any external
Forces like an offset balancer to make it docile at RPM would U ?
So IF I was to build what you’ve evaluated
I believe you’re in a good starting point for a nice powerful & smooth running powerplant !
LY rods are forged Aren’t they ??
You’re Cranks Balanced. good!
Put a FluidDampner on it with the Neutral
TC of choice for your stall & IMO youll
Have a well running high performance Mopar
PS
How about a FiTech FI Setup for the fuel delivery needs …. More smoothness for
Happy cruise nites & bountiful burnouts !
Mopar2ya!!
John
