440 Holley Dual inlet fuel line plumbing
Fuel and Air Systems
  1. Jim Maserejian
    Jim Maserejian Member
    11
    2
    Jun 11, 2017
    Evansville, Indiana
    Local Time:
    5:03 AM
    DIY not a mechanic looking at all the pitfalls before I begin the next project - switch from Edlebrock performer series to Holley Dual inlet 4160. Need advice on fuel lines (pump to carb) for '67 Coronet with 440, TF, stock intake manifold, aftermarket headers, Lunati cam and I recently updated to electronic ignition. Currently lines plumbed for Edelbrock performer 600 single inlet. Just for the heck of it, if I wanted a Holley 750 cfm 4160 (dual feed inlets), how much plumbing headache will I have? I don't have a Holley, yet. I'm afraid that the usual dual inlet chrome line for $20 will bump into the distributor. or coil. No return lines on this engine. If you've tried / done the conversion, looking for your advice.
  2. Jim Maserejian
    11
    2
    Jun 11, 2017
    Evansville, Indiana
    Local Time:
    5:03 AM
    RSD-PCY05S_s.jpg Found this on Summit Racing - looks like it would solve the problem.
    • Agree Agree x 1
    • moparedtn
      moparedtn Ed on the Ridge FBBO Gold Member
      6,485
      9458
      May 14, 2011
      On the Ridge, TN
      Local Time:
      6:03 AM
      You can use that one (they're real common, of course) but I can tell you on a 440 it's gonna require a little "redirecting"
      on the inlet end (sits low on a stock intake and aims at the distributor).
      • Agree Agree x 2
      • Joe66satellite
        Joe66satellite Well-Known Member
        210
        92
        Nov 30, 2018
        Las vegas
        Local Time:
        3:03 AM
        If you already have an Edelbrock on it you could just get an Edelbrock 750 CFM carburetor that's what I did reducing my ProForm 850 double pumper because I got terrible gas mileage with that thing and I couldn't get a very good idle out of it either just saying
      • dadsbee
        dadsbee FBBO Gold Member FBBO Gold Member
        5,846
        12538
        Jan 29, 2018
        Ontario, Canada
        Local Time:
        6:03 AM
        • Like Like x 5
        • Ratbastard
          Ratbastard Well-Known Member
          47
          118
          Apr 21, 2019
          Sun city ca.
          Local Time:
          3:03 AM
          8A959C91-75D5-4440-AE15-9C8B5F2D8910.jpeg 1E07FC5D-C3AF-472F-9776-A5C15E52D42D.jpeg Just like dadsbee did just run the duel fuel line backwards to the rear and run fuel line where you want. This is what I did.
        • Jim Maserejian
          11
          2
          Jun 11, 2017
          Evansville, Indiana
          Local Time:
          5:03 AM
          Thank you - Looks good. I was hesitant to to pull off the 180 turn. But it looks clean. Is a braided steel line a waste of time?
        • Jim Maserejian
          11
          2
          Jun 11, 2017
          Evansville, Indiana
          Local Time:
          5:03 AM
          dadsbee can you possibly get a pic of where the coil was moved to?
          Jim
        • dadsbee
          5,846
          12538
          Jan 29, 2018
          Ontario, Canada
          Local Time:
          6:03 AM
          Right where it belongs.. well at least with one bolt!
        • Ratbastard
          47
          118
          Apr 21, 2019
          Sun city ca.
          Local Time:
          3:03 AM
          You won’t have a problem with u-turn, braided line is for wear and tear and looks only. Ran line along fender to keep fuel as cool as possible as long as possible. If looking for factory stock look, then run it right along the engine and intake as close as possible.
        • Jim Maserejian
          11
          2
          Jun 11, 2017
          Evansville, Indiana
          Local Time:
          5:03 AM
          Great pics thank you. Looks like a good size carb spacer seems to help the primary side bowl clear the coil. As an easier fit option, Holley is offering a single feed 750 cfm 4160 model - it's a bit smaller overall dimensions with the inlet on the driver's side front.
        • BBishere2
          BBishere2 FBBO Gold Member FBBO Gold Member
          537
          666
          Oct 5, 2013
          Fulton, MO
          Local Time:
          5:03 AM
          I took a similar fuel rail off of my 440 as the fuel line will plumb with a rubber hose over the distributor. I replaced it with a Holley fuel rail and a 90 degree turn down that gets the fuel line away from the distributor and gave a port for a fuel pressure gauge. Picked the parts up from Summit and they work great.
          • Like Like x 1
          • Jim Maserejian
            11
            2
            Jun 11, 2017
            Evansville, Indiana
            Local Time:
            5:03 AM
            Update - The dual inlet Holley's front primary side fuel bowl was all over the coil bracket. Rather than fabricate a bracket extension / move it, I ended up choosing a single inlet Holley 4160 which has slightly smaller dimensions front/back, allowing reasonable space for the coil. Maybe the '67 440HP stock intake manifold has a different set up for coil mount than later manifolds?
            A 1/4 inch carb spacer was required, with either dual or single inlet Holley 4160, to allow full movement of the throttle mechanism. Classic industries has a $15 pump to carb fuel line designed for OEM single inlet Holley carbureted Mopars.
            So it's not exactly stock appearing, but I will say the exhaust smell at idle is a lot more tolerable with the Holley 4160 than the Edelbrock Performer (no matter how I tuned the idle mixture screws, it just skunked - possibly because of the particular Lunati cam I guess). Thank you for all the advice and pics.
          • HEMI-ITIS
            HEMI-ITIS STREETER on LI FBBO Gold Member
            11,588
            13732
            Dec 14, 2008
            Long Island,New York
            Local Time:
            6:03 AM
            Sometimes there is no road map,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,:lol:
            • Like Like x 1
            • Agree Agree x 1
            • Ratbastard
              47
              118
              Apr 21, 2019
              Sun city ca.
              Local Time:
              3:03 AM
              Jim, I think the thing you learn most is, adapt and move on. Take notes, invent, live with your choices, and Enjoy your success. If any thing I’ve learned at car shows is what the hell was that guy thinking when he installed that piece on that car. Other then that, we’re all professionals. Enjoy your work, and always take credit for it!!!!!!!!!! This is what it gets you. Your peers will like your work.
              07108B24-1CC9-4275-82E8-FC31EA562C9E.jpeg 134CAEBD-7DF1-48D7-BF99-FCE6BA372909.png
            • TN Mopar
              TN Mopar Well-Known Member
              183
              150
              Dec 8, 2015
              Cleveland TN
              Local Time:
              6:03 AM
              This is what I did
            • cmkryzer
              cmkryzer Well-Known Member
              45
              6
              May 21, 2012
              Minnesota
              Local Time:
              5:03 AM
              dadsbee, I have the same issue with my fuel line also and like what you did. Two questions, first, did you run a hard line or a rubber line from the fuel pump up all the way ? and two, your mount for the fuel filter, that home mage of something you can buy stock? I like the looks of it !
            • dadsbee
              5,846
              12538
              Jan 29, 2018
              Ontario, Canada
              Local Time:
              6:03 AM
              Rubber line from pump, as it's an aftermarket with a hose barb.. not a threaded fitting. Filter holder is just a "tube clamp" of the appropriate size, I have 10's of thousands of them on hand so not an issue getting one the correct size. The effort was to hold the filter up in "free" air so it stays cool and not resting on the manifold and percolating. beerestoration2017 770.JPG beerestoration2017 772.JPG beerestoration2017 773.JPG beerestoration2017 774.JPG beerestoration2017 775.JPG beerestoration2017 776.JPG
            • HEMI-ITIS
              11,588
              13732
              Dec 14, 2008
              Local Time:
              6:03 AM
              With under,,,,,say 500 HP the small fuel line would be ok.
              • Agree Agree x 1
              • dadsbee
                5,846
                12538
                Jan 29, 2018
                Ontario, Canada
                Local Time:
                6:03 AM
                LOL.. it's a stock 383HP.. we don't all run monster blower engines!..............BUT we should!
                • Thanks! Thanks! x 1
                1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
                  By continuing to use this site, you are consenting to our use of cookies.
