Houle #382
Well my winter build didn't go as planned as nobody in the continental US has a Hydraulic roller cam that I was looking to buy. So back to square one but there's a small issue. My current setup is a hydraulic flat tappet cam with adjustable rockers. Here's my question, in order to set the Preload properly the lifters should not have oil in them so when you go to set the preload it collapse the lifter instead of opening the valve. My problem is all my lifters have oil in them and I can't collapse them so how do I set the preload?
