I am having an issue with low / no oil pressure after the car has set for about 18 months while I redid all the electrical wiring and new fuel system. This is not a new build on the motor and it had 50-60 psi when parked. Car was built as a drag car and I believe has a big cam in it, but no idea of the specs. Below are the steps I have taken to fix the oil pressure issue:
1) Replaced the oil pump that came on the engine with a new Melling High-Volume oil pump (M63HV). Installed new oil pump gasket and o-ring on the pump shaft. Primed the pump before installing by soaking in oil and manually turning the shaft.
2) Changed oil with Mobil 1 High Mileage Synthetic 10w-40 and new Mobil 1 filter (M1-301a).
3) Installed mechanical oil pressure gauge (Autometer #3321 Sport Comp). This is connected to the driver side oil pressure port on the back of the 440.
4) Pulled distributor and can manually drive the oil pump with a Dewalt 20V cordless drill and priming tool.
5) I removed the oil filter and ran the drill. Oil poured out of the hole when drill was running, so it seems the oil pump is fully primed.
6) Reinstalled the new oil filter and ran the drill for 2-3 minutes. I am getting oil up to the port and through the nylon tubing that came with the gauge, but it only drips out of the end of the tube (4-5 drops per second). I've read that with proper pressure, it should shoot out of the tube (not just dripping). When I connected the tube to the back of the gauge and ran the drill, I can get 5-7 psi to read on the gauge.
7) Engine will start and oil pressure gauge won't go above 7 psi.
What am I missing? Could the oil galley become blocked without running the engine? How can I clean the oil galleys without remove the engine (if possible)? Any help would be greatly appreciated as I am getting anxious to get behind the wheel!
