PurpleBeeper
I've read the sticky & links.
I've got a 440 and am replacing the rear main seal with a viton main seal & the silicone side seals in a Hughes "cap". As many of you know, the silicone "cap side seals" really want to slide out while you're pushing the cap up/in (engine in car). Is there an adhesive I can use to hold the silicone side seals in place better while I install the cap? I do have a small amount of assembly lube on the outside of the side seals, but they keep wanting to pop out as I slide the cap in. IDEAS? Thank you
