lxmodguy
Gen3 Hemi Guru
****Updated to include fuel system and complete ignition****
40 over 440 12.5:1 compression
Eagle forged cranked
Manley forged rods
Ross forged pistons
Hydraulic roller cam 242/248 .600 .610 110
(Aggressive ramps w supporting springs)
Crane hydraulic roller lifters
Indy ez-1 max wedge port heads
Indy mod man manifold (port matched, ported, smoothed and powder coated
(Efi w fuel rails, 80# fuel injectors)
102mm Fast Throttle Body
Fast ez efi 2 controller and harness (weather pack connectors, plug and play with control for the fuel pump, 2 electric fans)
EFI Fuel Pump, E85 compatible fuel line, fuel pressue regulator, all -6 fittings to hook up the feed line
Crane gold 1.6 roller rockers
Smith bros custom pushrods
Milodon 7qt pan
Powder coated aluminum valve covers
MSD billet pro distributor (configured for EFI)
MSD 6AL
MSD 8.5 Wires
Too much invested to give every detail. Includes billet serpentine pulleys, gm type two power steering pump and adapters, 140 amp one wire alternator and low mount billet bracket. Aluminum water pump.
10,500 Firm. Everything is new. Have receipts. About 70-100 miles on the motor. It is INSANE fast. If you didn't know it was a 440 you wouldn't believe it.
This is essentially a plug and play, completely configured, EFI setup ready to run
Manley forged rods
Ross forged pistons
Milodon 7qt pan
MSD 6AL
MSD 8.5 Wires
