YY1
Not really sure where to put this...
The 69 440 in my truck had a TQ on it and ran, but backfired and wouldn't stay running.
I finally figured out it was leaking gas internally, and swapped it out with an eddy AFB 600.
After adjustments it's doing MUCH better, and is street drivable now, however...
The electric choke works correctly, and it starts fine cold, or if you shut it off normally.
If I stall it (it's a manual trans) or let it die while tuning, it won''t restart unless I pour about 1/4 cup of gas in the carb. I've tried pumping the pedal, but that doesn't seem to do anything.
I've checked for vacuum leaks (and so has my brother), and can't find any.
The motor seems to have a cam (I intend to pull a valve cover and measure lift), and I'm sure the 600 is too small, but it seems to run OK enough to drive.
I've got it to idle at about 1150 warm (I'd be happier with less), and it carries about 12-14 inches of vacuum.
The timing is "below the marks" advanced- I'm guessing about 14-16* initial, and it doesn't ping or diesel, or exhibit timing related hard starting.
Additional info- electric fuel pump, and it seems to want a rich idle mixture- about 3 3/4 turns out.
If I Turn the screws all the way in, it dies (it stayed running with the TQ).
I sprayed carb cleaner all around the base gasket, the sides of the carb, all the blocked off nipples, the intake to head gasket, and as far as I could get under the intake. No effect.
It's actually surprisingly easy to drive, considering what it is- a full size truck with a cammed 440 and a linkage clutch manual trans all with questionable installation and maintenance.
Any ideas why it's starved for gas on a stall induced restart?
