Paul_G
- 2:51 AM
- Dec 24, 2013
- Surprise, Arizona
The build has started. My machinist checked the block out and gave it a clean bill of health. No cracks, the bores will clean up at .020, but I need .030 with the stroker kit I am using. The decks are a little out, but will clean up with a very light cut. He rattled off the numbers to me, I didnt write them down. I am having the machinist install the rotating assembly in the block for me. I will take the block home and finish the build myself.
I am going with the 440 source 440 to 512 kit, 440.512.5060. This one was recommended by Ken at 440 Source for my application. I am using the aluminum PP240 heads, this should have the compression ratio land in the mid 10's. This will be primarily a street engine.
The goals;
1st, I need enough vacuum for power brakes
2nd, it must run cool with the A/C on
3rd, make the most power it can within the limits of 1 and 2 above
4th, sound like a muscle car
My build plan is;
· 1978 440 block built to a 500" stroker
· Trick Flow PP240 heads 78cc
· hydraulic roller cam for streetability
· Eddy Performer RPM dual plane intake
· Long tube headers
· Going to use a carb
The car it's going in;
· 4000# 1972 Charger with A/C, power steering, power brakes
· comfortable cruiser
· 8 3/4" diff with 3.91 gears
· 46rh overdrive automatic
· lock up Hughes converter with 2400 stahl, this can be modified by Hughes if need be.
I need to spec a cam. Give me some ideas. The cam needs to work with existing OD trans and rear gear, and preferably with the converter as well. Can a hydraulic roller cam do what I need it to do better than an old school hydraulic flat tappet cam?
The goals;
My build plan is;
· Long tube headers
