512 build for 68 charger
cdr
11:17 AM
Pattison Texas
4.380" bore 4.250 stroke 6.536 H beam rod 440 SOURCE STROKER KIT
(.040 over) -24cc dish
1.320" 9.9 to1 comp
Indy single plane intake
Howards solid flat tappet .579 lift 247 @.050 duration
TREND tool steel solid lifters
440 source SUPER STEALTH heads flow 330 @ .650 lift,,,
THIS IS A STREET BUILD, yes the Charger has COLD A/C 3.91 rear gear, a518 overdrive with lock up torque converter
Holley 900 cfm EFI, might sell the holley efi & do port injection.
400 block
street porting & cutting to max wedge intake,heads done now to the machine shop
http://vid1198.photobucket.com/albums/aa453/cdrmorsports/1stmovie%20%204.mp4
the link above is a short video of my car
Very exciting Charlie! Sounds like an absolute animal that will definitely add to the fun factor. Enjoy
Wow, I would love to say im not envious, but i sure hate to lie! lol, id love to be able to do some of this kind of the build right now, a power plant of this magnitude lurking in the corner wouldn't hurt anyone! great stuff bud!!!
Very nice! I'll be curious to see how the 512 is when done. beast I'm sure!
Nice! I was thinking about using 440 source myself,, curious to see how you make out with their parts
I like it. I like the black. I like the fact that the car was done in a real persons garage. If I ever do another car a 68 Charger is at the top of the list.
Doug
Very nice. I used the D-dished piston and I beam rod from 440Source you see here also on my 493 with EZ heads at 10.6 comp. They work nice as with the D-dish I still built a nice .046 quench in the eng to run fine on 92 pump. Is it done yet and do you plan to race it any ? Ron
Thanks DVW!! & 383 man everything is at the machine shop & yes it will go to the strip, due to health reasons i will probably have to let someone else drive but thats ok,, I am truly blessed to be able to have & build my car!!!!
it should mph in the 119 ish area, we will see :)
good luck looks like a great start
good luck
looks like a great build
just got my block & heads back from G&G performance Co, out of Tomball texas,Chris & Joe did a great job!!! and the build begins.
