62 plymouth What are these?
Derv
3:25 AM
Calgary
look like they are ready to go......but where?
Top radiator support bracket, to the inner fender. I can send a pic if needed
Wow that would be great. Thanks
slight correction...with those brackets, it's the lower horizontal support mounts. I can't get in for a pic, because the grill is in the way
No worries thanks for help will keep trying to peice this thing together
I think I may be off again.
The center vertical support, between the upper and lower has two brackets that reach out to the grill to support it, I believe that those brackets are what you are showing. Mine are bent ever so slightly different, but mine is a Coronet
