gregpurcell
This is a v8 frame from a 66 Plymouth Satellite. It is in pretty good used condition. It has been sandblasted and painted gloss black and it's ready to install. The unit has far less dents and dings than some I've seen. As you know, the 66-67 Mopar B body used the same K frame for the small block and the big block engines (except Hemi) so you only need this part if you are converting from a slant six OR if your current K frame is damaged.
It's located in Savannah, GA. $200 plus the ride which should be about $50.
