Dump that electric fan. Get the right shroud and fan on it.heres some pics of my setup
So many go to electric fans and have issues.Dump that electric fan. Get the right shroud and fan on it.
Luckily looks like the proper shroudDump that electric fan. Get the right shroud and fan on it.
Is that the right size rad?To me it looks like you are not moving enough air, in fact I think you are blocking air flow. Get a proper 18-18 1/2" fan. Possibly a thermal clutch too.
Howdy. Yes,storms chased us all the way home.Hey D1esel, hope your trip was good! As a few here have eluded to, I'd recommend getting a proper mechanical fan.. the one you have isnt doing much, and quite possibly blocking airflow at speed. I use those on my drag cars. They are just good enough for cool downs
It's a 69 C body radiator for a 440 automatic. It's listed as a 28" radiator. It should be capable of proper cooling. Look closely at the mounting when adding a fan, because you need the fan centered in the shroud. Also use a proper size spacer so that all but a half inch f the fan is inside of the shroud.Is that the right size rad?
Yes, sold though. Thanx for informing meThere's a correct fan and clutch for sale down in mechanical. Not sure that the fan clutch will work. Fan blade is correct.
Get a Flowkooler pump if you can.
Gauge was reading correctly.I have an infrared temp gun and plan on doing just that
Update on my heating problem. I replaced the water pump with a 6 blade impeller as opposed to an 8 blade original one. I removed the electric fan,installed a 7 blade 18".Hey D1esel, hope your trip was good! As a few here have eluded to, I'd recommend getting a proper mechanical fan.. the one you have isnt doing much, and quite possibly blocking airflow at speed. I use those on my drag cars. They are just good enough for cool downs
FANTASTIC NEWS!Update on my heating problem. I replaced the water pump with a 6 blade impeller as opposed to an 8 blade original one. I removed the electric fan,installed a 7 blade 18".
It now runs at 180 around town. On the highway it creeps up to 210 but begins to drop as soon as I get out of the throttle.
No,they just frown. I am really enjoying working on my car instead of same old same oldFANTASTIC NEWS!
Have your Bow tie friends shunned you yet, or are they still communicating???
A fan blade should be half the thickness of the blade in the shroud and half out for it to work correctly.It's a 69 C body radiator for a 440 automatic. It's listed as a 28" radiator. It should be capable of proper cooling. Look closely at the mounting when adding a fan, because you need the fan centered in the shroud. Also use a proper size spacer so that all but a half inch f the fan is inside of the shroud.
