Panheadchuck
looking for a non ac dash frame that in good shape uncut , no rust etc ,
im not sure but ill take some ppics if you have them . ill check on the 66Will a NON AC dash frame from a 1966 Plymouth Belvedere work?
I can get pics if needed.
A 66 is different at the area where the column passes through the dash and the trim that covers the opening is smaller. A 66 column is smaller diameter than 67.
Coronet dash is different, the gauge cluster run’s all the way across and meets the glove box door-there is no metal between the gauge cluster and glove box door like a Plymouth has.
So they are all different from each other, Ply & Dode, 1966 and 1967. 4 unique dash frames.
