68 Charger quarter panels
So thats my color PMB Wildberry pearl mid 90’s Dodge color
Seems there are a few Chargers with a fresh paint job this spring. Sprayed the clear on mine yesterday, SPI universal clear, great stuff, easy 1:1 mix ready to spray. Piled on 2 good wet coats at 60 degrees it flowed together nice.
That car is turning out to be pretty amazing, now you got me wanting to detail the undercarriage on mine some more :lowdown:
Heres an area that needs attention before you paint, should have looked at the gas cap trim ring closer, the white marker needs to be cut out and screw holes drilled offset so it sits down in the dish right.
Cant wait to bolt this rascal in there. Fresh 383 and 727.
Starting to come together now that the body and paint is mostly in the rear view, testing out all the electrical now on the car before the engine/trans goes in. Only problems so far just grounding issues from all the new paint and primer.
These would have been good 4th of July pictures
Pretty easy to put the dash in and take it back out by yourself, I set it on a platform made from cardboard boxes, a piece of plywood and a soft dog blanket, then hook in the 2 side mounts and it pivots up and down
