WTB '68 Roadrunner Trans. Cooler Lines, Ignition switch, Lock set.
cummins6turbo
4:19 PM
Pittsburgh, Pa.
I'm restoring a '68 Roadrunner, and I need trans. cooler lines. I have the originals, but someone cut / shortened one, and used an external cooler. I'm returning back to stock. The engine/trans is 383/auto. I also need the ignition switch, and lock set (trunk, doors) with keys. Located in Pittsburgh, Pa. 15106. Thank you in advance for your help.
i have a brand new set of transmission lines from a 1972 Roadrunner 440 with a 727 transmission if they will work. I'd take $40 plus the ride from Buford GA 30519. Never installed still in the box
Just take your old ones and copy them with new tubing. Just need a flare and bending kit to make your own. You can use it to do your brake and fuel lines as well.
It cheaper and you can say you did it yourself.
If you make your own these need to be double flairs. I have not had very good luck with cheep flairing tools.
They make a cooper/zinc alloy tube now that's very easy to bend and flare. I know it's not org but it might be worth looking into. I use a ton of it for brake lines and it's suppose to never rot. Also I've used trans cooler lines from year one on a 68 I had and they worked really good. All the bends where right and they fit good.
Just bought a new set from inline for my 68 RR, fit great 40-50 bucks Phil from Corpus Christi
