Ed Martin
When the 2-speed wipers on my 68 Roadrunner quit working after years of not being used (since I don't drive in the the rain), I replaced the (orginal) motor. That did not fix the problem so I figured the next step was to check out the wiper switch. When I look in my FSM page 8-83 it says to test the 2-speed switch, disconnect the wiring and remove the switch from the instrument panel. Then refers to page 8-75 for removal of the instrument cluster and lists 13 steps for doing this. Has anyone made any sense of this:
INSTRUMENT CLUSTERS (Fig. 7)
Removal--Belvedere and Satellite Models
(1) Remove steering column trim cover (four mounting screws).
(2) Roll carpet back and remove lower mounting plate (four mounting bolts).
(3) Remove steering column clamp (two attaching nuts).
(4) Remove upper trim moulding (six screws), (so equipped).
(5) Remove left side trim moulding (one screw), (so equipped).
(6) Remove left side trim plate by removing one mounting screw and on “T” bolt, (so equipped).
(7) Remove radio trim plate (two screws).
(8) Remove the four switch bezel mounting screws and remove switch bezel.
(9) Remove ignition switch. See “Switch Replacement”.
(10) Remove center air conditioning opening cover (so equipped) by removing one mounting screw.
(11) Remove lower trim pad (six mounting bolts under the panel and four mounting screws from front panel).
(12) Disconnect speedometer cable from under panel.
(13) Remove six cluster mounting screws and rock the cluster out, disconnect wiring harness and remove cluster.
HUH?
What is the alternate way to extract the wiper switch anyone has used? Thanks for your help.
HUH?
