'69 GTX console question
orty
New Member
2:35 AM
wisconsin
I have a factory automatic console that came with the car. My car is a 4 speed and I was wondering if this would work with the right shifter and different panel.
I believe that you can buy an aftermarket piece for the left side of the auto console that will let you convert it to work with the 4 speed transmission. I'd suggest that you check around with some of the Mopar suppliers.
Yes. It's all the same console. What you do is cut out an arch and part of the left side panel where the floor hump is and install the aforementioned 4 spd hump and trim piece to cover the hole. I have a template I can send you.
