Stereolab42
Follow-on from my thread in the Welcome section. Here is the 70 Coronet R/T I just bought:
I'll repro what the fender tag decoded as here:
Some facts about the car:
To that end I want to create a to-do list. I'll try to consolidate my questions in this thread. I'm sure there will be many!
To-do 9/29/2018
WS23:
Dodge Coronet,Charger
Special, R/T
2 Door Hardtop
U0A: 440 375HP 1-4BBL 8 CYL
1970
Lynch Road, MI, USA
109628: Sequence number
E86: 440 cid 4 barrel V8 (High Performance) 375hp
D32: Heavy Duty Automatic Transmission
EF8: Dark Green Metallic (Dodge), Ivy Green Metallic (Plymouth) Exterior Color
D6F8: Trim - Luxury, Vinyl Bucket Seats, Green
EF8: Dark Green Metallic (Dodge), Ivy Green Metallic (Plymouth) Int. Door Frames
826: Build Date: August 26
065295: Order number
V1F: Full Vinyl Top, Green
N96: Fresh Air Hood
M46: Simulated ¼ Scoops
WS23:
Special, R/T
2 Door Hardtop
1970
Lynch Road, MI, USA
N96: Fresh Air Hood
- Almost certainly a Cali car all its life. This underwent a full resto in the 2000s and I have some pics. There was literally no rust of consequence on the original body panels.
- Engine block is definitely numbers-matching. I'm told it was bored 0.030 over during the rebuild.
- Transmission is allegedly original internally but the case was replaced due to a crack. Oh well. This gives me an excuse to throw in an overdrive trans if I want to someday.
- Exterior color is NOT the original Mopar metallic green, but a darker metallic green (I'm trying to get the paint code, allegedly it's a GM). The black stripes are metallic black and are painted on.
- Vinyl roof and interior are now black, but were originally green.
- Other than the colors, the wheels, and the radiator, it seems effort was made to keep the car original. Even the original front disc brakes are still there.
To-do 9/29/2018
- Perform a full detail at some point.
- Fix small paint bubble near rear window trim. (It's not rust, maybe bad surface prep. Inject glue?)
- A few exterior plastic pieces are somewhat tired and should be replaced.
- The center of the hood doesn't quite lineup properly with the bumper. Resolve this.
- Replace hopelessly pitted driver's side remote mirror.
- Replace hopelessly pitted vent window brightwork (ugh, working with vent windows SUCKS, I know this from my GTO).
- Replace wheels and tires with something more period-correct.
- No spare came with the car. Source spare-tire hardware.
- Replace all fluids in the car so I have a fresh starting point.
- The Wizard radiator has a leak and will be trashed. Get a new one (another Wizard? An OEM Mopar repro that doesn't suck, if such a thing exists?)
- Touchup some paint on the engine.
- Replace some of the things in the engine bay that should be shiny but won't cleanup.
- Transmission and oil pan gaskets have slow seepage. Replace the gaskets.
- Replace the Magnaflow mufflers with my favorites, the Flowmaster Super-40s.
- An exhaust pipe is pressing up against the floorboards and causing vibration. Fix that.
- Decide if I want to add QTP exhaust cutouts so I can dump headers at will.
- Replace busted rearview mirror.
- Fix bad sun visor ball joints.
- Replace the tired steering wheel and horn cap with OEM repros (for an absolute fortune, but they are in disastrous shape).
- Fix the broken horn.
- Fix the broken autocancel on the turn signal.
- Wood veneer trim in the car is mismatched and mostly tired. Replace as needed.
- Diagnose and fix non-working fuel gauge.
- Alternator gauge reads backwards. Fix it.
- Diagnose and fix non-working blower (and maybe heater core?).
- Diagnose and fix non-working wipers.
- Replace incorrect and tired armrests.
- Restore or replace the janky glovebox.
- Dash pad is in good shape, but the metal area in back of it needs repainting or major touchup? Do this.
- Replace various tired interior switches, knobs, and other misc pieces.
- Right quarter window doesn't go up all the way. Fix.
- Clean or polish out old stains/scratches in side windows.
- PO added a thing under the dash to hold an aftermarket radio, along with kick-panel speakers. Replace all this with more modern hardware.
- Replace front seatbelts with 3-point seatbelts.
- Replace rear lap seatbelts with new lap seatbelts.
- Install a Lojack.
- Get personalized black Cali plates.
