70 Roadrunner Drive Shaft Question
1968 -1970 Mopars
  1. RoadRunner1970
    RoadRunner1970 Well-Known Member
    287
    108
    Dec 5, 2012
    US
    Local Time:
    5:58 PM
    Is there any difference between a 4 speed and automatic as far as the drive shaft is concerned? Would a 4 speed and an automatic take the same length drive shaft?
  2. 727
    727 Well-Known Member
    521
    413
    May 18, 2015
    Mississippi
    Local Time:
    4:58 PM
    Not sure if there is any difference in diameter or strength from the factory but length was the same. I swapped from a 727 to a 833 and used the same drive shaft.
    If you have a two piece shaft with a rubber isolator you should change it out for either transmission.
    • Thanks! Thanks! x 1
    • HEMI-ITIS
      HEMI-ITIS STREETER on LI FBBO Gold Member
      11,872
      14217
      Dec 14, 2008
      Long Island,New York
      Local Time:
      5:58 PM
      I don't thing so,,,,but what do I know....................:rolleyes:
    • 68GTX4SPEED
      68GTX4SPEED Well-Known Member
      783
      156
      Dec 21, 2009
      Sweden
      Local Time:
      10:58 PM
      If it is a 440-6 or a Hemi there will be a difference, because of the Dana 60, that driveshaft needs to be 1.14" shorter.
      • Agree Agree x 1
      • Photon440
        Photon440 FBBO Gold Member FBBO Gold Member
        9,882
        9306
        Mar 14, 2012
        Surrey, B.C. Canada
        Local Time:
        2:58 PM
        I used the same shaft with both a 727 and a four speed in my '70.
        • slepr1
          slepr1 Well-Known Member
          1,426
          1189
          Jul 19, 2014
          Stoney Creek, Ontario
          Local Time:
          5:58 PM
          Same length in my 71 Cuda
        1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
          By continuing to use this site, you are consenting to our use of cookies.
