Just put a 3” TTI exhaust system on my 70 RR. Also bought the Chrime tips to go with it. Before I cut the tailpipes how far are they supposed to stick out past the bumper?
Thanks!
Thanks!
You fit the tip's tabs inside the slots on the mount.
Perfect. Thank you!I just measured mine. As stated above, they are near the lower edge of the bumper. See pictures:
The level is up against the bumper. Left side measures 4" in from the bumper/level and the right side is 3 7/8" These were NOS tips from the 1990s.
TTI is backwards, nothing like factory. BewareYou fit the tip's tabs inside the slots on the mount.
The tabs are on the pipes. Not the tip. You have to cut the pipe to put the tips on on TTI stuff (tongue twister )
Very important cosmetic detail. Good job. Get it right. This 69, with factory plumbing intact.
