1ol74charger4me
Nice 72 steering column that will fit 71-74 b body. You can slip this over your existing steering shaft or just change the upper housings. Good attributes are; the spring setup to return the release collar works very well and lines up good, it has a goodworking turn signal switch and the plastic collapsible joint cover is in excellent shape and it has been retrofitted with a later model lower bearing assembly for smoother operation. Minus attributes are; hazard switch is broken, no ignition lock and needs paint. $100 sent to lower 48. PM and will take Paypal. Thanks.
