Did these b-body's road runners, gtx, charger,satellites ever come with a remote passenger side mirror? If they did was the remote control near the ash tray in the dash?
They look just like 71-74 rallye mirrors on the outside (also had a non-rallye version), but the mounting changed from screws countersunk through the pedestal, to a back side screw arrangement into cast on protrusions that required dimples stamped in the door skin.
Not entirely sure where the joystick ended up, but the cable is looong.
I have two sets and eventually will see if I can modify them to work without changing the door skin.
Might grind off the protrusion and simply drill a hole through so it mounts like 71-74.
