I love you, man!!On a ’72, the hose passes through a hole below the A/C fan opening, near the A/C box drain on the passenger side. Large grommet molded to the original vacuum line. The connection would be at the same manifold fitting as the brake booster.
That is the original supply lineConfusing thing is on my car, the grommet under the A/C box appears it had a hose through it at one time. pic is from inside the car.
So, two Charger guys indicate the vacuum supply line combined with the water valve cable, never seen that way from the factory.
BTW, the original water valve cable hole is about a ½” in size, no way it would allow a vacuum hose to pass through with the original cable in the same ½” hole with a grommet.
What hole does it use?Well on my 74 is like that and a 73 of a friend of mine the same. Maybe a 73/74 diff with 71/72. Never have paid attention of that on my buddies 71/72s actually
The ’71-72 B-body firewall, inner fenders, and front frame rails are basically the same stampings as ’70-74 E-bodies. The picture posted is the same as the ’71 & 72 B-body. The labeling is accurate for A/C cars with one exception, shows three small screw holes around the grommet hole for the A/C vacuum supply, never seen that.
What hole does that cable use?I saw another picture with the holes, sounds like the ’71 A/C two hose grommet is secured with screws. None of my ‘72s with single hose grommets had screws or holes. Yea, the ’71 A/C with a vacuum actuated water valve also had a vacuum reservoir under the battery box. The ’72 and later, with a cable operated water valve, did not.
