Nick ciavarino
What is the correct amount of fluid needed after pans installed I drained the converter in which a little over 2 qts drained thanks nick
I looked it up b&m says it adds four qtr. ?I presume you mean a new 727 deep pan install, and you drained 2 qts out of the converter? A 2" deep pan usually takes 2 more qts than stock. If that is correct, I'd start with 7 quarts, start the motor & slowly add couple more quarts, go through the gears, fill to the add mark, then check & add when it's warmed up. Depending on converter size, may be 9-10 quarts, if a 12" converter, another 1/2 - 1.
It would have been easy to check with one of your wife's measuring cups while they were both off.What is the correct amount of fluid needed after pans installed I drained the converter in which a little over 2 qts drained thanks nick
