Just Call Me B
1973 plymouth satellite 340 727. Car shifted great. Forward gears still do. Reverse started to act like neutral until about 1500 rpm then brutally slams into reverse. I pulled the pan and the cup that holds the spring that i believe goes to the reverse piston had blown past its retaining clip and was hanging on the lever that activates it. I am obviously not up on correct part names. The lip on the cup was no longer flat. We flattened out the lip and reinstalled the cup. We were able to back out of the driveway twice and blew the cup out again. Lever bolt was set at 72 inch pounds and backed off 2.5 turns. Any thoughts would be appreciated. Thanks, Brian
